Ga door naar hoofdinhoud
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
169 Vragen Bekijk alle
Why doesn't itunes recognize the iPod nano?
When I plug in the ipod nano into the usb port. Itunes doesn't recogize it. How can I make it show up and work on itunes
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Don't know if this will work, but it worked on my 5th gen Ipod.
Plug it in to your to your Mac or PC via usb cable. Open iTunes. Then Hold the volume down and the sleep bottom until the Nano reboots. If it still doesn't appear on your iTunes but it does appear on your desktop, then there is a problem with your firmware. You may have to find the firmware on the web or look it up in youtube.
Hope that helps. Have a good one.
Was dit antwoord nuttig?
Score 1
Same solution. Worked perfectly: hold down volume down and sleep button simultaneously until reboot Apple appears. Let it boot up and it should now appear in iTunes Devices.
Voeg je antwoord toe
Jamie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 4,938
