Want my phone to show caller ID when we make a call to someone else
We want our home number to show on the receivers phone but since installing this phone it comes up as No ID so lots of people wont answer the call
Is dit een goede vraag?
Hi @bokahux3 ,
Blocking or unblocking outgoing Caller ID is a facility provided by the phone service provider.
Depending on your phone service provider, you can either go to their website and search for how to block/unblock outgoing Caller ID (usually by dialling a code from your phone) or you may have to contact them as they might not offer this facility as a user controlled setting but as one that is set permanently on your phone service by them at your request, as either unblocked, blocked or blocked with override,
If your phone service is a VOIP service, you may be able to check your phone service account online to see if the outgoing Caller ID facility is set to block. If it is, unblock it, save the change and then test if it works OK. (sometimes it takes a little while for the change to be applied - it depends on your ISP)
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 130
