PS4 not boooting just making random beeping sounds
Hello.
A customer came in earlier with a PS4 because he had some connectivity issues with the HDMI port which is actually a very common issue on the PS4. So i went ahead and told him that the HDMI port probably have to be changed.
I opened the PS4 up and checked the HDMI port. Everything looked fine so i went ahead and tested it on our TV. When i plugged in the power the PS4 starts making what seems to be random beeping sounds. I then opened it up again and checked all the wires and connectors to see if i have missed something. Everything was fine so i put it back together and tested again. Same thing. Immediately after i plug in the power cord the beeping sounds start.
I have searched google and ifixit and have not come across anyone experiencing this exact issue. I found many people who had similar issues but as far as i could tell they never resolved it. I have attached a 2 minute video link where you can see and hear whats happening.
https://photos.app.goo.gl/cRJ9UyiWM8dFCK...
Questions:
Did i work in an anti static environment: Yes at all times.
Did i use anti static wrist bands connected to a grounding point: Yes at all times.
Did i check and clean all the connectors involved: Yes.
Did i make any physical changes to the PS4: Other then opening it and putting it back together, no.
Does it turn on: No.
Does it eject disk: No.
Does the controller connect: No.
Did i try taking out the HDD and turn it on: Yes.
Is any of the lights on: No.
Hopefully someone has experience with this issue and knows what it is, how to fix it and how to prevent it!
Is dit een goede vraag?
2 opmerkingen
Just a quick question. Have you ever tried to see if it makes the same sounds without the HDD plugged in?
door toreskey
Didn't think of that Just tried it now and the issue is still the same. :/
door Total Repairs AS
