Ga door naar hoofdinhoud
2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Vragen Bekijk alle
MacBook Pro not charging. Solid Green Light
Ok so when I plug in the laptop, the light is green and doesn’t change to orange. When I turn on the computer, the computer says its not charging. Ive already tried a SMC reset already. The battery was left in the computer for about 4 years without use so the battery is probably at 0%.
Sometimes, the light will change to orange, the battery indicator lights will light up, then the light will change green and then the computer will say not charging.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
With a battery unused for such a long time it’s no wonder it doesn’t take charge. First step in my opinion would be to replace battery, that’s probably all you need to do.
Was dit antwoord nuttig?
Score 2
Het nuttigste antwoord
Let’s get a better look at the condition of that battery with a better tool and then we can advise you better. You may have to select an older version than the current one:
How to Test a Mac Laptop Battery
Score 3
Voeg je antwoord toe
jimmysofat6864 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 293
