Ga door naar hoofdinhoud
2018 refresh of the Apple Mac mini. Processor options include 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5, and 3.2GHz 6-core Intel Core i7 processors.
80 Vragen Bekijk alle
How difficult to upgrade the memory ourselves?
The new 2018 Mac mini uses SO-DIMM for memory. From the official pictures, it seems easy to upgrade the memory ourselves, but we hope you folks can help us confirm how difficult it is to upgrade. Thanks!
Is dit een goede vraag?
Score 13
16 opmerkingen
for pro person is piece a cake - for someone who unable to hold screwdriver - impossible
door
was lead to believe you just popped open the bottom and replaced the ram module with another chip of similair specs. but video i just watched doesnt make it seem like you can just “pop it open”. this is the exact reason i bought the mini. and im not going to pay apple 400 euros to add 8gbs of ram to it.
door
I just received my 2018 Mac Mini also and took off the cover and the T6 screws, I saw where the memory cage was though I am not sure what need to be removed to access it. Looking forward to some videos on how to do the ram upgrade. For now I am stuck with 8GB of ram
door
I am writing this on a freshly-upgraded 2018 Mac mini, having just replaced the two 4GB RAM modules with two 16GB modules. I can say that the procedure was quite a bit more complex than I had anticipated, given the photos I had seen of the RAM just sitting there exposed, looking able to just be popped-out of the bottom of the case.
In fact, you will need the right tools AND a bit of careful skill to accomplish this task. Took me less-than an hour.
If you have ever worked on the inside of a prior generation Mac mini … to replace the HDD with an SSD for example … this job is roughly equal in difficulty to that. Beware, there are some *delicate” connectors that you can break if your are not careful in removing them!
door
Search Youtube there’s plenty of tutorials available now! Have Fun!
door
11 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Here’s the guide on doing it:
Mac mini eind 2018 Vervanging van het RAM-geheugen
Was dit antwoord nuttig?
Score 7
2 opmerkingen:
Refer to the guide @mayer linked on how to do it. My opinion based on what I seen in the teardown is it varies. For someone exprienced, the attempt Apple made to hide the memory is a joke. Give me 30 minutes tops and I’ll have this thing done. Once I've done it once, I'd expect to half that time.
This one may be more difficult for average users like the Aspire One ZG5 was. I wouldn’t want someone like my dad to try this without assistance, at least for the first time. I’d probably monitor someone like him after 1-2 assisted installs to see, but I would need to make sure they can get it right without damage consistently.
door
Nice guide. Just finished upgrade and it was easier than I imagined. Only problem was stripping the head of one fan Torx 6 fan screw while tightening it. Any idea where I can get a replacement?
door
I’ve just seen the first video of ram upgrade here
https://www.youtube.com/watch?v=L3FKmOwl...
Update (11/07/2018)
more videos on YouTube about it
this one is better explanation of it so far
https://www.youtube.com/watch?v=2UrSLnnM...
Score 4
1 Opmerking:
Except for the removal of the RAM clip covers which is unnecessary. That and not calling attention to the two cable connectors when re-seating the motherboard. You have to make sure you don’t pinch them.
door
Voeg je antwoord toe
Bob Roy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 5,762
