Leaking water into the cup along with the coffee
I use my Keurig B40 with K Cups and plastic refillables. Both have the same problem. Yesterday, I noticed that water was flowing into my coffee cup along with the coffee. This makes for a rather weak cup of coffee . I thought that there was a leak where the top needle punctures the K Cup. I removed the rubber seal aroung the needle. I cleaned the seal and the surface around it. There was a lot of old coffee around the needle.
I reassembled the seal and made a new cup of coffee. The same thing happened. When the brewing was complete, I removed the K Cup. The top was dry. I found the same thing with the plastic reusable. Water is bypassing somewhere, but the top is dry.
What should I do next?
I found the problem after taking the top cover off the Keurig B40. The hose to the water injector had pulled loose and thus most of the water was bypassing the K Cup. I put it back together and the problem is fixed for $0.
Is dit een goede vraag?
