Is it good practice to soak PCBs in alcohol?
Hello all!
So I’m going to make a second attempt at repairing my Xperia X after removing the metal covers over the NAND, CPU, and some other components. I can’t see any corrosion, but I’ll clean it with alcohol just in case.
Over my experience of repairing this device, I’ve soaked the motherboard in isopropyl alcohol (90% alcohol by volume) multiple times for about 72 hours in total. I want to know if that soak can wear down the traces on the motherboard (which might be launching me into even more uh-oh). If it does wear the motherboard down, how much does it wear away? Given my current soaks, would it have worn away traces?
Thanks in advance!
Is dit een goede vraag?
1 Opmerking
It shouldn't wear away but instead of soaking get an ultrasonic cleaner and you won't need to soak
door daniel
