Ga door naar hoofdinhoud
Device repair information for the 1080p 60" Projection TV by Mitsubishi with model number WD-60737.
27 Vragen Bekijk alle
Why are there streaks down the screen?
There’s steaks running vertically down the picture on the tv, no color just plain streaks on the left facing the tv.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
cbean8737
could be a lot of things. anything from a bad component on the PCB to a bad DLP chip. This model Mitsubishi had issues with the light engine, which could be a cause as well. This is not going to be an easy or inexpensive repair and will require you to do some very intensive troubleshooting. I’d start with the PCB and check for obviously damaged components.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
cbean8737 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 60
