Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
1981 Vragen Bekijk alle
Is nondestructively replacing iPhone 7 home button glass possible?
Anyone know if there’s a way to nondestructively replace only the glass circle (roundlet, surface, whatever you want to call it) on the iPhone 7 home button? This would be for the purposes of modding the colour of the button in order for it to match a black display installed on the silver variant of the phone. Incidentally, anyone know of someone who has successfully pulled off this colour swap? Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ive done it using heat and OEM button. First attempt to use glass only from ebay was unsuccessful. Touch didint worked. So ive used spare button as a donnor . And regarding adhesive- UV curable same as you wold be using for digitiser only repair
Was dit antwoord nuttig?
Commentaar:
Okay, interesting. If I do this, I would probably get a sacrificial button to try that on first. Any specific tips though? Or a link to a schematic or teardown of the button assembly? Would be great to know what's under the glass so I know how gentle to be/where to pry if necessary.
door
Voeg je antwoord toe
InternetDenizen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 39
