My screen is cracked but touch is working fine
Do i need to replace the touch digitizer or lcd too. its just cracks on screen. where can i get it done
Is dit een goede vraag?
Looks like you can replace just the Digitizer; but you are better off just replacing the entire screen assembly. Replacing the screen is hard enough because you have to remove every other part in order to replace it. You will also need the skills and tools to be able to separate the screen and digitizer which I am assuming you do not have.
I provided a link to a new screen assembly and a tutorial on how to install your new screen assembly below.
Was dit antwoord nuttig?
Hello Akki9897
The digitizer and the LCD are united, it is possible to separate them and change only the digitizer, but for that specialized machinery is necessary and there is a good chance that you will break the LCD and have to buy the full screen. I advise against it, it is easier and more reliable to change the screen completely. If you find a frame, it will make repairing a lot easier.
Bye
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 81
