Ga door naar hoofdinhoud
The ASUS Essentio is a tower PC manufactured by ASUS, identifiable by the model number CM6870. Released in 2012.
8 Vragen Bekijk alle
Turns on but will not display anything on the monitor or tv
I have tried: Replacing the c mos battery, replaced the power cord, replaced the vga cable, I have done a hard reset, with no luck nothing is working when i turn it on, then it turns off for less then 10 seconds then turns back on and nothing comes up on the monitor.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Clean the motherboard my motherboard was covered in dust and after cleaning it it started working…
Was dit antwoord nuttig?
Het nuttigste antwoord
Let’s perform a bit of troubleshooting first. You mentioned checking and replacing the VGA cable. Have you tried some of the other video ports? The easiest one to try would be HDMI, as you could connect it to an HDTV to see if it’s just a problem with your VGA port. I doubt that is the reason, because you mention it reboots after about 10 seconds, but it’s worth a try. You also said that you changed the CMOS battery, but let’s try clearing CMOS using the jumper located on the motherboard. You can do this by following the steps outlined in your motherboard’s manual:
Should this not work, we may need to begin testing components. Do you happen to have a replacement power supply or a power supply tester handy? Power supply testers can be bought pretty cheap from virtually anywhere computer parts are sold (or Amazon/eBay) and can help you quickly identify if your power supply is at fault. Without a tester, a replacement power supply would be handy to have to connect and see if your computer properly powers on and boots.
Should the power supply seem to be ok, let’s try something else. With the power cable removed from the computer, remove all RAM modules from the motherboard, reinsert the power cable, and then power on the computer without any RAM installed. Does the computer produce a series of beeps? If so, go ahead and power off the computer, disconnect the power cable, and reinsert the RAM modules and try to power on again.
If the computer produces no beeps, then your computer would seem like it’s not passing POST (Power On Self Test), which is a low-level, fundamental test that computers go through before boot takes place. This would indicate that your motherboard would be at fault and would need replacing. Your model seems to use the P8H77-M-PRO motherboard.
Hope this helps.
Score 2
Update the bios see if that helps
I have removed the ram but there was no beep sound
1 Opmerking:
@kushith19 this is a 5 year old question and not often visited. If you have an issue with your device, you need to start from scratch. What make and model computer is it? What are the issues with it? What have you check and what have you tried to fix it?
door
Voeg je antwoord toe
Jen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 26
Altijd: 1,576
