Ga door naar hoofdinhoud
Repair and service information related to Dell Inspiron 15" (inch) laptops.
170 Vragen Bekijk alle
laptop screen is not working, but can hear Windows log in sound
I pressed the power button to resume my laptop from sleep, the blue lights on the machine indicated that it does wake up, but the screen is not working.
I pressed the power button again to turn it off.
And then turn it on again, the screen shows this,
DELL
Inspiron 1525 series
BIOS Revision A16
After that, the screen turns black, doesn't show anything.
But I can hear the Windows sound (Windows log in sound).
I take the battery out and put it back in, then turn on the laptop, the screen is still not working.
I repeat these steps, still got the same issues.
My laptop is Dell
Intel(R) Pentium(R) Dual CPU T2390 @ 1.86GHz 1.87 GHz Windows 10
How to fix this problem?
Is dit een goede vraag?
3 opmerkingen
Try connecting it to a monitor , what happens
door
I don't have a monitor.
door
I would find a cheap monitor on Craigslist or LetGo. Either that or see if you could borrow one from a friend.
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Have you tried to connect a separate display to the laptop? If that doesn’t work, it sounds new enough that you could get the warranty to cover it. If not, and the screen works when it’s on a separate screen try to see if the screen connector cable is inserted properly
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Unfortunately, I don't have a separate display.
But I tested this laptop screen by shining the flashlight on the screen, I was able to see all the processes since the machine started working, the BIOS screen, Windows logo, log on screen, and finally my desktop, but all these were very dark, without the flashlight I couldn't see these.
Does this test tell us anything?
door
I know on MacBooks if the inverter isn't working the same thing happens, so why not look into a new inverter?
door
Hi @awtech ,
If you can see images when using a flashlight this indicates that you have a backlight problem.
This could be caused by a faulty or loose inverter cable, a faulty inverter board or a faulty LCD panel.
Here’s a link to the service manual for the laptop. Scroll to p.21 to view the location of the inverter cable.
Here’s a link to a video that shows how to replace the inverter board. (view it in conjunction with the service manual on how to remove the display assembly)
Here’s a link to a supplier of a replacement inverter board for your laptop. It is shown just to give you an idea of the cost of the part. There are other suppliers online that may suit you better.
Hopefully this is of some help.
Score 1
Hi, I am Dev Irugurala. Sometimes it may cause due to carbon deposited on RAM pins . Jus open the Laptop backend cover carefully and remove the RAM after that Clean with eraser gently and replace back to the position. Now close the Laptop back cover and power ON . You will see the display on Screen. I hope, it will be works. Why don't you try if not do yet..?! Thankyou
Voeg je antwoord toe
awtech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 131
