Window will roll down but won't go back up
I done tested motor and if I reverse polarity it will roll up so I changed the switches. Both driver side and passenger still gives me same problem someone gimme advice
Is dit een goede vraag?
Score
0
How did you do the test? Did you supply the voltage from elsewhere or jump across the terminals at the connector for the switch?
door Travis
