Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Computers die over het algemeen geen geïntegreerd scherm hebben, en die bedoeld zijn om te blijven staan.
1219 Vragen Bekijk alle
Possible hard drive upgrade
Hi all,
On my latest build I have my Windows 7 performance readings at 7.3 or higher except for the hard drive stuck at 5.8. My current drive is a WD 500 GB --7200 rpm and I am considering replacing it with either a 10,000 rpm Raptor or a SSD. Due to my lack of experience with either I am looking for some input on the best way to go.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
Nintendo Switch-kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
3 Antwoorden
Gekozen oplossing
I personally never just replace a hard drive in my PC, I usually just add a second hard drive. The Windows performance readings really don't mean much. If you're looking for a reliable form of benchmarking, try GeekBench. My main hard drive is a 1TB 7200RPM Western Digital Greendrive. It only gets a 5.9 in Windows. You won't get much better performance, withour upgrading to something like an SSD.
Was dit antwoord nuttig?
Score 1
Commentaar:
Thanks--this is the kind of info I am looking for. +
door
Was hoping for more input but doesn't appear likely. The reading I've been doing seems to back up your statement so I'm accepting your answer. Thanks again.
door
Het nuttigste antwoord
I passed on this question because it was PC related but it really doesn't matter. I usually put the Raptor drives in machines that get heavy hard drive access and need a higher level of reliance. A heavy duty Mac truck meant for staying on the road all the time for the long haul vs. the high speed sports car. I'l put my money on the Raptor for reliability.
Score 2
Commentaar:
Thanks for your input--do you find the Raptors are noisier than a 7200rpm drive?
door
yes, but usually just on start up
door
Even you add an 10.000 rpm disk, should work faster.
Anyway, have you tried to defragment your actual hard disk?
Don't add an SSD or your system will only be faster at boot, but the global system performance will be decreased.
SSD Hard disk drives are only faster reading, but not so fast writting.
Score 1
Voeg je antwoord toe
rj713 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,147
