Ga door naar hoofdinhoud
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
512 Vragen Bekijk alle
Need iMac power supply voltage pinout. Short fan spin then dies
Hi guys,
I’m working on the 2011 27” imac and it gets no power.
  • I only get Diagnostic LED #1 on
  • When I press the power button, I get momentary fan spin then it stops
  • I don’t know what the power supply pin voltages are supposed to be, but out of the 14 or so pin points, I only get a measurement from TWO : 12v and 3.9V
The customer has also reflowed this unit due to the GPU problem, but would the GPU prevent the machine from getting boot power?
Hoping someone can provide the power supply pinout voltages so I can see if it’s logic board vs PSU. Thanks!
Is dit een goede vraag?
Een opmerking toevoegen
PC Laptop batterijen
An easy fix for a big power boost.
Nu winkelen
Nu winkelen
1 Antwoord
Het nuttigste antwoord
Not sure if this will have what you need but this is suppose to be the schematics for it: https://www.scribd.com/document/27449012...
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
KRepair zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 55
