how do i get architecture back
trying to install driver into the terminal with a command line
now when i try to open the terminal it says it cant open because it is not supported by this archetecture meaning applications
Is dit een goede vraag?
What file did you move, rename or delete?
Can't help from such scant information.
N.
Was dit antwoord nuttig?
i was in aplications/utilities/terminal
i accidently deleted the information in the contents folder
now when i try to open the terminal it says not suported by this archatecture
thats where i am now please help
all because of ethernet adfapter
== You need a new copy of terminal... == if you have install DVD/CD you can use [http://www.versiontracker.com/dyn/morein...|Pacifist} to extract one and drop it into Utilities.
Get the proper flavor of Pacifist for your OS.
Good Luck,
N.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 693
1 Opmerking
you appear to have 3 questions about drivers all posted within a day or so - I assume it's all a related issue. instead of posting 3 separate questions (including this very vague one) you should post follow ups to the same original post
door bac
