Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
778 Vragen Bekijk alle
YLOD to RLOD after update
After doing a Sony Update, my system rebooted and then flashed the YLOD then went to the RLOD then turned off. I have checked the Hard drive to make sure it was seated and replaced the past on the CPU Sinks. Since Sony wants $150.00 for the repair, I am hoping to do the repair myself. I am a Certified Computer Tech, but have very limited knowledge on these gaming systems. Is there anything I can do to fix this problem?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There's a very good chance that it is bricked. This means that the software is corrupted, and the system cannot start up. You could try to boot it to the recovery menu, and re-install the firmware. Hold down the power button until it turns on, beeps a few times, and shuts down. Now, hold down the power button again, until it beeps twice, then double-beeps. If successful, you should see a menu on the screen, saying to connect a controller. Select the "Rebuild File System" option, and let it complete the process. If you cannot get to the recovery menu, then there is no way for you to fix the problem, and you will have to send the PS3 to Sony, or replace it.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the answer, I will try that tonight when I get the chance.
door
Voeg je antwoord toe
Brian Wall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,919
