Ga door naar hoofdinhoud
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Vragen Bekijk alle
Can I replace a 2009 iMac 20" LCD Display with a 2007 2-" LCD?
I have a very dim and banded 20” LCD display on my Early 2009 iMac and I have a 2007 20 iMac with a good display just gathering dust. Can I swap out the displays?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi Roger,
Based off of the Everymac pages for the 2007 and 2009 20” iMacs, I’d say it just might be feasible. If you’re willing to open the 2007, you could compare the connection cables as seen in Step 8 of the 2009 20” iMac teardown. If they look similar, it might be worth a shot.
Though before you open anything, take a peek at this page to see if you can find anything that might help in your case. If you know the EMCs then it’ll help you determine compatibility of screens like this one.
Hope this helps!
iMac Intel 20" EMC 2133 & 2210 Glass Panel Afbeelding
Product
$89.99
Was dit antwoord nuttig?
Voeg je antwoord toe
Roger Clay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 159
