Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Boot loop - cannot update/restore
(Doing this on the behalf of someone who is currently unable to access their Apple ID and is currently overseas)
iOS Version: 11.4.1 Build 15G77
Device: iPhone 6
Not jailbroken and never has been
Uses iCloud to backup - last was 26th of Aug
Last online: 3rd of September (According to MDM)
Had the battery replaced on the 6th of July by one of the Apple Stores
Prior to the battery change, all iOS apps were crashing. Getting a new battery fixed this. (Device was restored too)
I will keep this as simple as possible but also try to explain it sufficiently.
So the phone has no storage left and now it only shows the apple symbol when booting up, nothing else. I believe that it is stuck in a boot loop. I have seen other users have the same problem with no solution to the problem.
On a friends computer, the person attempted to update the device via the latest version of iTunes however the update failed and stated that it must be restored.
Cannot restore due to the two-factor authentication code which is sent to that device.
The image below shows what happens before updating/restoring:
Since the device is recognised, I have considered suggesting the use of a 3rd party program such as "dr.fone" in order to attempt to recover data/ remove the loop. Wanting to keep restoring to the last resort.
Would appreciate any suggestions.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The phone should be able to be restored through iTunes as long as you put the phone into recovery mode, you do this by turning the device completely off than holding the home button for 5 seconds and plug the device in still holding the home button until the phone shows a plug into iTunes logo on iPhone 7 or newer turn the device off hold the volume down button and the power button for 5 seconds plug it in and hold until screen comes on. This should go around two factor authentication also you can try going to iCloud.com and restoring it from there but if anything remove it from your account to deactivate two factor authentication. good luck
Mr Umph Phone Repair
Ashley Bellows, David Bellows, Gavin Bishop
Have a nice day
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
V_S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 435
