Ga door naar hoofdinhoud
5-inch draagbare voertuig-gps met levenslange kaarten en verkeersinformatie (niet langer geproduceerd door de fabrikant).
Why does my device not turn on unless it's plugged in
It’s actually a Garmin nuvi 2995 but that isn’t listed.
It will only turn on when plugged into the car, my PC or a USB charger, then it works OK.
I’ve left it plugged into a USB charger for over an hour, but it still won’t turn on unless it’s plugged in.
Can anyone suggest a fix ?
Is dit een goede vraag?
Score 2
4 opmerkingen
are you sure that is the correct model number? I can't find anything about a 2995 model
door
I made 2 mistakes, it's a 2559 and, I thought charging it for an hour would be enough, it wasn't.
Charged it overnight, all ok now. Found out where to buy replacement batteries though.
Thanks for the help.
door
I have the same issue with a brand new Garmin ETREX 22x.
door
I have that problem with my Garmin nuvi55. Bought a new battery & still have the same problem
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Your battery unfortunately has probably gone bad google the model number and see if its repairable lucky in 2018 theres a video for everything. I don’t know if Ifixit will have parts for it try ebay if not look for good vendor.
Was dit antwoord nuttig?
Score 1
My mistake, I thought charging it for an hour would be enough, it wasn't.
Score 1
1 Opmerking:
where can I you replacement batteries for the Garmin Nuvi? Thanks for the information.
door
Voeg je antwoord toe
Frank Edgar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 2,168
