LG wt1501cw won't agitate
My LG top loader recently started having an issue. When I start a wash cycle, it does the load sensing, fills with water normally, then instead of starting to agitate back and forth the whole drum slowly rotates in one direction. It will continue to do this, and the timer never gets shorter. The spin function works fine on it's own. During load sensing the agitator moves in both directions, and I've taken everything underneath apart short of opening the bearing housing so I don't think it's the clutch or coupling. What could be causing this?
Is dit een goede vraag?
5 opmerkingen
I have tried to enter test mode by holding down the water plus and spin button and hitting the power button, but it just turns on normally. If somebody could explain how to get test mode working I that may help as well.
door tatumj96
Anybody have any suggestions?
door tatumj96
Yes . Mine did the say . I had to check the wires from inlet valve from the red connector . Under the tap a blue wore was cut in half and you could not see it .
door terrydarlene
Mine did same thing and I found a penny stuck in the bottom problem fixed after I took the agitator off.
door John Glover
My lg inverter 10 kg washer will not adgitate, only 6 months old
door Janine williams
