Black screen on 2015 iMac 27" retina with loud fan
This question is asked for one of my friends.
He has a 2015 iMac 27" retina system, recently he got the screen replaced, however, when trying to power it on, he can hear the chime sound, but nothing showing on screen, screen is totally black, instead, the fan is very load.
He tried to connect it with an external monitor, it is running and OK, but nothing displays on internal screen. He tried to do SMC reset, no help.
Can any one advise what's could be wrong here?
Is dit een goede vraag?
Thanks for all your reply and suggestions. One more thing to ask, is backlight, either backlight unit or backlight cable, easily damaged when opening the display unit? It looks to me that the adhesive is on all edges, it should be safe just cut off the adhesive itself. Correct me if I’m wrong.
door Tom
You must follow the IFIXIT guide here iMac Intel 27" 5K Retina-scherm Vervanging van het scherm make sure you use the tool supplied in the adhesive strips which you'll need before you open the system [gekoppeld product ontbreekt of is uitgeschakeld: IF174-005] and you'll need a few of these as well Plastic Cards I use four just to make sure I don't damage the display which is very easy to do!
door Dan
