Ga door naar hoofdinhoud
Repair information for Whirlpool dishwashers.
156 Vragen Bekijk alle
Why won’t my dishwasher dry my dishes
I replaced the heating element on my whirlpool dishwasher but it still won’t dry the dishes. The water gets hot enough to fog my glasses but will not dry the dishes. How can I fix this? I included a picture of the control panel and the model number. It didn’t give me he option of my dishwasher in the devices.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Cause 1
Vent
The vent might not be opening properly. As the dishes are drying, many dishwashers use a vent to let out the hot, steamy air generated during the rinse cycle. If the vent does not open properly, the dishwasher will leave moisture on the dishes. Check the vent to ensure that it is opening properly.
Cause 2
Vent Fan Motor
Some dishwashers use a vent fan motor to help dry the dishes at the end of the cycle. If the fan motor is not working, the dishwasher won’t dry the dishes properly. To determine if the fan motor has failed, test the motor for continuity. Also, try turning the fan blade by hand to ensure that it spins freely. If the fan motor has burned out or the fan blade won’t turn smoothly, replace the vent fan motor.
UPDATE
For Bosch Dishwasher Ascenta models, open the door to reset it. Hold the Start-Reset button for about 5 seconds or until the Active indicator turns off. Shut the door of the dishwasher to allow it to thoroughly drain before turning it off. When the dishwasher completes draining, it beeps to indicate that it is done.
For models that have a clock display, hold the combination Start-Resetbutton until the clock display changes to 0:00. Close the door of these models and wait until the clock reads 0:01 before pressing the On-Offbutton.
Check out the dishwasher not drying page for some additional fixes and explanations.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
All the research I’ve tried to do says to reset my dishwasher in order to reset the heating element...does anyone know how to do this with the control board I have?
door
Voeg je antwoord toe
Tabatha Andrews zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 22
Afgelopen 7 dagen: 76
Afgelopen 30 dagen: 225
Altijd: 6,757
