MacBook2,1 shorting when keyboard attached.
I recently purchased a top case cable for mu MacBook2,1. When I replaced it any put the computer together, it turned on briefly & then turned off. I took it apart & lifted the keyboard off of the lower case, & pressed the power button. It booted up. I then put the keyboard down & it immediately shut off. I’m assuming it is a short because after trial & error, I discovered touching the metal near the underside of the power button with the metal of the frame near the Bluetooth antenna causes the computer to turn off and not power on unless thee pieces are not touching anymore. Does anybody have a solution or explanation? The cable was purchased off of amazon & is one of the silver type. I checked it for continuity on the outside of the cable but it didn’t not seem to conduct.
Is dit een goede vraag?
