2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
442 Vragen Bekijk alle
Replaced Battery, now only runs w/ power adaptor
I just replaced my battery using the repair guide here and did everything properly (as far as I’m aware.) When I went to turn it on, it would not turn on. After I plugged it into the charger it turned back on but showed “Battery not charging” and the power source is adaptor.
I reset the SMU and ran the Apple Hardware test but both indicated no issues. Everything runs fine otherwise and I have not noted anything else wrong. It is running off the charger… which makes me thing that isn’t the issue. I even dis/reconnected the battery part inside the computer just to be sure.
Any ideas on what I should do next or how this has been fixed before? I haven’t found any similar issues on this site after doing the battery replacement.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
try to check your battery health by using any app
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
3 Antwoorden
Gekozen oplossing
@swagner3 Let’s do some testing of the battery. Download and run coconutBattery and attach a screenshot of the coconutBattery window.
Attaching Images to an Existing Question
Was dit antwoord nuttig?
Score 1
Commentaar:
Just updated it. Thanks!
door
@swagner3 Odd. It says its good, but the darn thing won't charge. Just to be sure, you should get another replacement just in case it is just a faulty replacement battery. iFixit supplies these types of batteries and they have a 1 year warranty on them where you can return them anytime for any reason. MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
door
Awesome, I will send them an email as well. Thanks!
door
@swagner3 Alright! Let us know how it goes!
door
Honestly, it sounds like a bad battery. If I’m not mistaken, the battery has its own board, with protection circuits and so on, maybe it’s damaged/faulty.
I contacted support and they sent a new battery, which has been working great so far!
So my answer would be to contact support and request a new battery.
Thanks all,
Sam
Voeg je antwoord toe
Sam Wagner zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 43
