Ga door naar hoofdinhoud
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Vragen Bekijk alle
Broken speaker connector on ipad 3 motherboard
After replacing the battery on the iPad 3 I found that the sound connector on the motherboard has broken off. Is there a place where I can get the connector soldered to the motherboard to fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. There are many shops worldwide that do this so you shouldn't have any problems finding them. Talk to them and ask how they do their work. Focus on good practices like proper cleaning of boards once completed etc.
If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
I have requested estimates for the soldering of a new connector to the motherboard which was broken. Thank you for your answer and suggestions for the repair needed!
door
Voeg je antwoord toe
Dean Jackson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 89
