Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1194 Vragen Bekijk alle
No Cameras or flash
Iphone 7 Plus "Both" Cameras and Flash not working. Customer said that it had previous water damage, took it to a shop for ultrasonic cleaning and it has been good for months... no issues till he tried using camera the other day and discovered both were not working. No visible signs of why... FPC Diode readings okay... anyone else experience this and what you did to resolve? Thank you
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hey Michael, good to have you back!
Hmmm…water damage…you know what I say in regards to latent issues :>).
I once had a similar water damage situation on a 6S Plus where everything probed okay but still didn’t work, despite replacing the LDO’s etc. It drove me nuts until I realized that the the VCC_MAIN wasn’t fully connected between the RCAM LDO and the rest of the VCC_MAIN. When I probed it in diode mode, I got a similar reading (I didn’t notice the slight discrepancy at first) but what I was reading on the VCC_MAIN pin of the LDO was actually the other downstream FCAM LDO and the values were almost the same. When I finally realized this, I tested the continuity between the RCAM LDO VCC_MAIN pin and the rest of VCC_MAIN and sure enough, they weren’t connected. The inner trace had probably blown due to the water damage.
The circuitry is a little different on the 7 series so you’ll have to dig around but make sure that there is actual 4.2V at the input of the LDO.
Was dit antwoord nuttig?
Score 3
Commentaar:
Thank you for taking the time to provide a great answer to my question. I tested both cameras and both worked in test housing... I only had a few 7 plus housings with what I thought were good cameras, so I tested them and convinced me that they were good when tested good in test housings and did not work in repair phone. I didn't have new cameras so got them from one of my competitors shop and walla! cams came back to normal. I have just been puzzled by it all and gave up trying to make sense of it all because it made absolutely 0 since! So, after repair, it was rebooting and voice memo was not greyed out but had error "No audio device found", I reballed and ran C12 jumper and it fixed the voice memo but not the intermittent crashes every couple minutes. I replaced Tristar without testing just to save time and it worked! Everything is 100% I just got distracted by life, my new brick and mortar shop 100 miles south of home & haven't contributed much due to business picking up not leaving much time.
door
Great!! Congrats on the new B&M shop but 100 miles...ouch!
door
Actually, It was a pain but done purposely to get into a better market for my business. We live in a small country town of about 8,000 and moved to a larger Indiana University town downtown to capture a market nearly 10 to 20 fold
door
Best of luck!! I know you will do great!!!
door
Voeg je antwoord toe
Michael zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 161
