My computer charge ports is not working
I don't know what to do. I really need a computer, I’m low income, I don't know whether to scrap the computer or fix the charging port I really can use you help guys!
Update (08/28/2018)
OK, guys
lt’s a A1278 Mid 2010
OK, so here everything I know: It was running with bad battery 0 percent for a year the charge cord keep it going I wiped the keys done with alcohol like they said fiber clothes the keys stop working so I did something something stupid and blow dry them with a hair dryer it was set to hot I ended up melting the keys! Just a few.
I also hit the charge port with lil heat that while a hour using my computer it just shut of I cut it back on 30 mins later it shuts of again then I cut it on 40 mins cuts off but doesn't cut back on charge port was green it powered on after holding the button for a min then start to boot then cut off start to boot cut of while the charging port light is getting dimmer and dimmer until it wasn't lighting up at all.
That's all I know, can you tell me what I need to do cause I need a computer fast!
Is dit een goede vraag?
