Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6s. Available in Silver, Space Grey, Gold, or Rose Gold with 16/64 GB storage options. Model A1662 and A1723.
923 Vragen Bekijk alle
White vertical lines screen partially unresponsive
The iPhone was dropped and now there are 5 vertical white lines on the right side of the screen. Where the white lines are the screen is unresponsive. However, when I diconnect and reconnect the screen I can sometimes manage to get the lines to switch to the left side and then that side becomes unresponsive.
Any ideas other than replacing the screen and digitizer?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
This is a connection issue. Often when connecters are not seated properly (especially on the 5 series and SE) the screen displays bars.
Id suggest removing the display, checking the connectors arnt damaged, clean the connectors with isopropyl and see how it goes from there. Also, make sure the cables are not getting twisted or stretched when laying the screen back down.
Was dit antwoord nuttig?
Score 1
Commentaar:
Sounds like the screen needs to be replaced either way if it happens after a drop.
door
Voeg je antwoord toe
Kyle Benning zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 265
