Ga door naar hoofdinhoud
Vind oplossingen voor je vragen over reparatie van je computer.
21227 Vragen Bekijk alle
Disk usage 100%, nothing running
So task manager shows my disk usage is 100%. I am currently not doing intensive pc work. What is causing this problem and how can I fix this? Screenshot included
Is dit een goede vraag?
1 Opmerking
I have a Alienware x51 R2
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Had this problem on a number of computers running Windows 10.
Current (March 2019) Windows 10 Updates fixes most of this high drive activity.
Spy-Bot’s Anti-Beacon software will block most of MicroSoft’s snoopy telemetry software which also causes much drive activity.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
This is very common in windows 10. I wasn’t happy when mine was doing this so i installed an SSD. Problem solved
Score 1
1 Opmerking:
Everything worked well before, a couple of months now my pc is getting slower.
door
The computer is busy because Windows 10 is doing one of its many updates. Currently (2018) the only easy workaround is : let it run some hours while you are away…
For more help, you may read “Why are Windows 10 updates so slow? “ (may 2018) : https://www.techadvisory.org/2018/03/why...
How to protect computer from cryptojacking
https://techfordaily.com/how-to-protect-...
Voeg je antwoord toe
Ruben Debbaudt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 566
