@mariosolis79995, User Ayrix is saying that they managed to remove the old socket from the board and, instead of replacing it with a new socket, they took a cord with a micro USB receptacle on one end and cut the wires, stripped them and soldered the bare wires directly to the circuit board. Now, instead of having a socket mounted in the chassis, they have a cord sticking out with a socket you plug your cord into.
That avoids the problem of finding the correct replacement part since any cord will work; it doesn't have to match up with the solder pads on the circuit board like a socket would. It would actually be possible to locate a replacement part as there are literally hundreds to choose from, but the problem here is that we can see from the photos the four solder points that provide the mounting for the socket, but we can't see the five solder pads where the pins of the connector solder onto. Without knowing what those look like, it's impossible to correctly identify a replacement.
If we could locate a picture of those solder pads I'd be happy to try and find a replacement.
