Ga door naar hoofdinhoud
The TI-Nspire CX handheld features a full-color, backlit screen, thin sleek design and includes TI-Nspire rechargeable battery.
My calculator does not turn on
So my TI stop working and when i try to turn it on it gets stuck and it says “system error “ and a symbol of a yellow triangle with exclamation mark appears, but I don´t know what it means.
What can I do to repair it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@bluesoul wall try to access the maintenance menu by holding [Doc][Enter][EE] and pressing the reset button on the back. In the maintenance menu, try 2 (erase OS).
If the problem persists, try 4 (full format - all data will be lost).
If it's not enough, another try with 2 and 4 usually completes the cleaning and solves the problem.
If nothing else you could try to access the diagnostics by holding [Esc][-][Menu] and pressing the reset button, then check for the options listed in there. Let us know what you got.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
leo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,422
