The screen has been damage, How can I fix it? it has a black dot ontop
There is a black dot on the upper right of the screen.
were to fix it?
or is it better to get a new one.
Thanks for the help
Is dit een goede vraag?
were to fix it?
Thanks for the help
George Wille okay, you figured out it needs a new LCD display. Depending on your model it is relatively easy and quick to fix those. I would repair the screen instead of replacing the GPS. Let us know what model your Garmin is and let’s see what we can figure out.
George Wille okay so the LCD is available but darn it is expensive. Common price seems to be around $90 USD. To get to it is looks like you start by removing the 8 screws from the back and remove teh batteries. That should gain you access. Once you remove those, post some good images of what you are then looking at. It will help if we can see what you see. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that.
Was dit antwoord nuttig?
Thanx, I have a Garmin GPSmaps 78 (color screen).
how can we make this work out.
Garmin 1010 screen is damaged and needs replaced where can I get it done
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 922
3 opmerkingen
My Garmin is the GPSmap 78 Color screen.
door George Wille
okay so the LCD is avaialble but darn it is expensive. Common price seems to be around $90USD
door oldturkey03
So, what next?
my email is, Gwille@gmail.com
were to send you the gps.
thanks
door George Wille
