Ga door naar hoofdinhoud
The Plantronics CS50 Headset is a wireless digital headset system manufactured and marketed by Plantronics, Inc.
Why can't I hear anything?
My CS50 works perfectly on one phone, but when I move it to another phone, I can't hear anything. It is installed correctly, and when I press the button on the headset, the regular receiver shuts down. But I cannot hear the dial tone through the head set. I haven't changed any of the settings on the base. Am I missing something?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @jf6 ,
Try moving the configurations setting switch on the base unit, through numbers 1-4 to see if you can get dial tone.
Here’s a link to a video that shows what I mean (1:20 minutes into the video)
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you. It still does not work. Very puzzling,
door
Hi @jf6 ,
Being a bit pedantic but the video shows that you press the button on the headset first and then you lift the handset off the phone but you say "when I press the button on the headset, the regular receiver shuts down" which to me indicates that you're doing it the other way around.
I realize that it should transfer from the handset to the headset but am wondering if the sequence has to be in the correct order.
Apologies if this is what you meant.
Is this 2nd phone the same make and model type as the first that you have no trouble with?
door
Voeg je antwoord toe
J. Kessler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 645
