Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
731 Vragen Bekijk alle
I keep getting signed out of the playstation network
Everytime I try to connect it keeps saying you have just been signed out of playstation network. I have re-tested the wireless Internet connection and everything works fine except for not letting me sign in to the playstation network. Can you please help?
Is dit een goede vraag?
Score 5
8 opmerkingen
I AM GETTING THIS ( error code 8002A537 ) EVERY TIME I LOG IN TO PS3 AND my ps3 keeps freezing up and all so i keep losing my sound of game play but not the mic sound ?
door
@craig371 same $@$* here!
door
My ps4 every time i turn it off it makes me log back into my account when I turn it on and when I go on my games it makes me do all the beginning stuff again.
door
My ps3 says an error has occurred. Signed out of playstation network (error 80710016) or something like that then I go to test wifi and it doesn't even show anything but connection to internet and it address found it doesn't say psn found and all the other stuff please help I just bought a shark card in gta5 for 50 bucks
door
Have you found a solution to your problem??I have the same too!!
door
3 commentaren meer tonen
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Martin,Is this a new error? did you change any of the setttings? Has anything preceded this problem? You can give this a try. In the settings under network, disable Media Server and disable Auto Sign-in as well and see if that makes a difference. If that does not work at all for you, it could be that the IP address on your PS3 is wrong. That way your PS3 cannot connect via router to the internet, no matter what DNS you have configured. Set your PS3 to obtain the IP address and DNS server addresses automatically via DHCP from the router. You do not need to configure the OpenDNS servers explicitly on any connected devices, whether it be a computer, or PS3, or Wii, or iPhone, etc. I believe that there might also be issues that originate from the wireless controller, but I have not researched that possibility in depth.
There is plenty of info about this happening and I am sure it is not a hardware issue but a software setup problem. Check here and here as well Good Luck and I hope this works for you.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Could someone translate this into English? We don't all know what DHCP and DNS/OpenDNS means.
door
disable the upnp in custom network settings!
door
mine wasn't an internet problem, just one of my accounts on my ps3 won't sign me in. I did some reading on forums and it MAY be some kind of hack that little baby modders figured out to ban someone from psn for a day or two. I was kicking but with a rocket launcher on Advanced Warfare and one of them could have kicked me out. Did your game play !#^& off a modder? that might be what happened...
Score 1
4 opmerkingen:
Is this happening to all ps3's?
door
I also have same problem with my ps3 always say PSN signed out any idea what can it be done
door
yup lil dweebs with some new hack.. mine just got killed tonight.. maybe try signing in on another ps3 console
or just play my ps4 might be less cheating dweebs in there
door
my psn has been issues code
door
I dont have an answer its just a similar thing happening to me because i go on to minecraft ps3 and i try to go online but it says “you have been signed out from the psn. Online features of the game will not be available until you sign into the psn. Exiting to main menu” i am on psn but i have logged out and gone back in many times and i have tried to search up what is happening but it has not helped what so ever. Is it something to do with maintenance because it said it was but it also said that it’d take two hours but its been about 15 hours. Anyone know what is going on?
Score 1
3 opmerkingen:
And yes i do still have Ps3 in 2021 ??
door
My son is having the same problem today on our ps3
door
we are having the same problem in ours
door
Voeg je antwoord toe
Martin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 126
Afgelopen 30 dagen: 536
Altijd: 78,457
