Ga door naar hoofdinhoud
iPhone 7 camera not working! What's wrong?
Hello, I have an iPhone 7 with a non functioning rear camera. I bought this phone second hand. All I know about the device is that it has had a screen replacement before. The device takes video no problem but continues to show a white screen when ever taking a photo. I have looked at the schematics of the iPhone 7 and narrowed it down to one of the filters above the connector (J4501). I saw that the last filter (C2512) has been broken in the microscope (possibly by a screw driver or prying tool). Can this filter be the reason that I am only seeing white in the camera while the video is working fine? I have never done a soldering job that small before, please let me know if I have concluded correctly.
P.S. I've already tried replacing the camera with a known good so the camera module itself being the issue is most likely out of the question.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It appears that you have already diagnosed the problem and answered your own question for the most part here. This break would definitely contribute to any abnormalities with the camera. If you feel comfortable with trying to solder it then go for it but just be forewarned that these types of things don't usually end well.
=( Hope this helps.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
The thing is, I have never soldered something that small and with such little room to work with. I don't even think my soldering iron can even get inside there. I've never done a soldering job with such a space constriction as those filers above the connector. Is there some sort of professional service that can do this soldering job for me?
door
As for repair, look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. There are many shops worldwide that do this so you shouldn't have any problems finding them. Talk to them and ask how they do their work. Focus on good practices like proper cleaning of boards once completed etc.
If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
door
Voeg je antwoord toe
Dennis De la mara zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 106
