Ga door naar hoofdinhoud
Repair information for the Garmin Vivoactive HR smartwatch. Released in February of 2016. Model number: 010-01605-03.
21 Vragen Bekijk alle
Won't respond or charge
My watch was on low. attery amdnstopped responding, time is stuck at 5:09, non of the buttons work, I cant turn it off. The screen lights up when I press button but won't turn off. When plus into charger nothing happens. Please help:)
Is dit een goede vraag?
Score 2
1 Opmerking:
Let Try this
push the two buttons at the same time about 15 second.
The screen will light up again & will back to normal work.
Good luck.
Adisorn T
door
Voeg een opmerking toe
2 Antwoorden
Try removing the battery for 30 sec and replacing the battery. This should reset your watch.
Was dit antwoord nuttig?
Plug into the charging cable and power source, then hold power button for 5 seconds. This will enter forced test mode. Scroll through the screens and check your device statistics.
Voeg je antwoord toe
Gina marie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 33
Altijd: 6,514
