MacBook shows flashing? on screen
I tried to lift the hdd flex cable up so it doesnt make shorts with the body of the mac but that didnt help.
I tried following commands:
CMD + R
CMD + Option + R
CMD + Option + R + P
It is always the same. The startung sounds comes, than after about 15 seconds the flashing Question mark shows up.
So my question is, what could here be broken? If it is really the hdd cable. Could i just buy a hdd caddy downlod osX.dmg from internet, copy it to bootable usb and will it work than? Or could i just cmd option r and install os x from the internet?
Thanks
Is dit een goede vraag?
4 opmerkingen
Do keep in mind this system can only support upto El Capitan 10.11.x
As far as using a dual drive setup I would first focus on getting the HD bay working before going down that path.
What are your drive or drives you currently have that you are working with. Can you give us the make and models of each so we can make sure they are compatible.
door Dan
Well that I didn’t know, that it suppa up to 10.11
I have got only the black scorpio ( shich should be working) from august 2012 with 320gb and 7200rpm 3.0gb/s
And a usb with 16 and one with i gb
door Nenadbrateu
Does your machine have a split bottom cover?
door mayer
I cannot answer that, because i have a not original cover from an 2009 mac which is not split
door Nenadbrateu
