iPhone 5s rebooting loop after battery replacement
I recently changed my battery. After that everything seemed to worked just fine for a couple of hours. But when a was trying to calibrate the battery, doing a fully discharge, and then charge it, never turned on and began rebooting loop with a red screen that shows up sometimes.
I just have spend all my day trying to fix it with out solution.
- First I tried to do a hard restart;
- I changed display, (my old display works fine);
- I took out from display the proximity camera flex cable;
- Using the original battery.
I just don't know what else can be.
Please help me
Is dit een goede vraag?
2 opmerkingen
try putting the old battery back in, if it works as it did before then you know you have a dud new battery. check the charge in the new battery-it may be too low to charge (so when you allowed the phone to go flat it cant recharge) send it back..it will never come good.
door pollytintop
Hi! Done, didn't work. It still rebooting :(
door PJBG
