Ga door naar hoofdinhoud
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
20 Vragen Bekijk alle
Laptop won't turn on at first but LED turns on.
When I press the power button of my laptop for the first time to turn it on, it doesn't turn on but LED indicator turns on, after forced shut downs several times it starts and works just fine. If I shut down it for short duration it starts without any problem but if the duration is long it doesn't start in the normal way.
Is dit een goede vraag?
2 opmerkingen:
Your laptop has an internal battery, How´s the duration of it????
door
I have been using this laptop for two years now so I think the CMOS battery is not the cause of the problem.
door
Voeg een opmerking toe
1 Antwoord
I don't have any experience with this particular laptop but the first thing I do when I have strange issues with laptops is 1 remove all power after shutdown including power brick and battery if possible. Let it sit for a while then try and start it up.
The second think I do is make sure the firmware is up to date. there should be a utility from Asus that will do this so take a look a their support site and see what they have for this.
Was dit antwoord nuttig?
2 opmerkingen:
@dandunham , Thanks for the answer. Removing the battery for a while was the first thing I did when I encountered the problem but it didn't help me.
door
I was talking about that battery. Have you try it with the power cord only??
door
Voeg je antwoord toe
Nitesh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 195
