Ga door naar hoofdinhoud
The Google Pixel is Google's first flagship phone, released on October 20, 2016. The 5-inch AMOLED display device comes with 32 and 128 GB storage options and is available in three colors; Very Silver, Quite Black, and Really Blue.
My phone freezes on incoming & outgoing calls
Hi everyone! I purchased my google pixel when it was released. However, now it's useless as it freezes whenever i receive or make a call. Phone operates fine till I receive a call and then the phone freezes. It keeps showing the person calling animation and it doesn't go forward nor i can cancel the call. Thr phone completely freezes as soon as someone calls. Speakers and mic dont work. Shutting down the phone is the only option. I don't know what's wrong with the phone. Can't understand whether its the software or hardware.
I've already tried the following things:
1. Resetting and reboot
2. Installation of new software
3. Upgrading to latest os and then downgrading to previous one
4. Going on beta android P
All these things didn't really help. If anyone knows how to solve this problem please let me know.
Is dit een goede vraag?
Score 14
7 opmerkingen
Hi Haider,
I have been facing the exact same issue since the last 2 days. I have already done factory reset, side loaded the last OTA update in recovery mode, but the issue is still there. Were you able to fix yours? If so, please help out.
If anyone was able to fix his/her issue, please reach out to me @ ankan95.4.as@gmail.com. Thanks in advance
door
Same problem, on Android 7, 8, 9, and Q. Uninstalling the phone app only works for a while.
door
My iPhone 6s got freeze early this morning after upgrading the IOS 12.2 the moment I get incoming call then it’s freeze unless I turn the phone off please help me fixe the problem please it’s sucks me a lot please
door
My phone itel S15 dose same and even if you want to turn it off It can't go the only option is to remove the batteries.
door
2 commentaren meer tonen
Voeg een opmerking toe
8 Antwoorden
Het nuttigste antwoord
I had the same problem. it would freeze for incoming and outgoing calls.
I did factory reset - problem persisted.
try this.
Go to the Play store, search for “dialer”
Look for the Google dialer app (must be factory one from google already installed)
select uninstall.
when uninstalled, select update.
problem fixed.
Was dit antwoord nuttig?
Score 6
6 opmerkingen:
It worked!!! Thank you!
door
Only worked for a brief time again back to freezing.
door
Worked for a few minutes then went back to freezing. Very frustrating.
door
Restart and again installed the updated dialer now it's working, thanks
door
1 commentaar meer tonen
Just got off the phone with google and fixed my phone. these are the steps
settings
apps and notifications
phone
clear cache and storage
uninstall updates
play store
my apps and games
download update for the phone
worked for me after that hope this helped
Score 2
1 Opmerking:
Thank you! This worked for me :)
door
I have cleared cache memory, and data for phone app. Now uninstalled app to the most primitive diaper app from Google and then updated again. Today on 18-jan 2019. Hope this fixed issue.
Score 1
You might be testing a beta app. Try removing yourself from beta testing and get the public release version. Hopefully this works!!
https://support.google.com/phoneapp/answ...
1 Opmerking:
Fixed. I deleted every app on my phone, other than Google apps. It worked just fine after that. Must have been one of the apps my kids downloaded that was hijacking my microphone and freezing the system when I made a call.
door
Hello guys I am Samiha just update your phone and your problem solved
Go to Settings -> Apps & Notifications -> Advanced -> Permission Manager -> Telephone
Deny all apps for this permission only allowed Phone app.
After this restart and check your phone will work again as it was working before.
There is some issue with telephone permission when given to other apps. So whenever any apps ask for permission deny it or if it dont work without permission then allow it for a while till you want the app to work and then deny/disallow telephone permission for that app.
Whenever you see problem go to same option as mentioned above you will see some other app too have telephone permission which you have to remove and then it will start working again.
1 Opmerking:
My phone will not dial out it will not go to dial pad it will not turn off I cannot take the battery out and not make or receive calls says n call
door
I had this problem too but i was able to fix it. At least temporarily. Just follow these simple steps and let us know if it works for you or not:
  1. Go to Settings > Apps & Notifications > Phone
  2. Clear the Phone cache and storage
  3. Go to PlayStore and search for the Google Phone app.
  4. Click on un-install. This will uninstall the updates for this app.
  5. Restart your phone
That’s it. I followed this procedure and my phone has been working fine ever since. Here’s a Guide that includes screenshots: https://www.helpmegeek.com/fix-for-googl...
To fix a Pixel that freezes or won't respond, try the following steps: freeze, stop responding, or is stuck with the screen on. If these steps don't work, check with your device manufacturer. If frozen, hold down the power button for 30 seconds. Troubleshoot your phone by checking for Android updates, storage, and apps. Open the Google Play Store app, manage apps & devices, choose to update all apps or a specific app, close unused apps, and force stop apps. Make a list of apps causing problems and force stop them. If the problem doesn't go away, restart in safe mode. Restart your phone normally and remove recently downloaded apps one by one. Restart your phone normally and reinstall the apps that caused the problem. Consider resetting your phone to factory settings, which will remove all data from your phone.
Voeg je antwoord toe
Haider Ikram zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 49
Altijd: 33,204
