Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
The RCA 22” DECK215R is a full HDTV with model number M215HW03. Repair of this device requires special, nonconductive tools.
15 Vragen Bekijk alle
Why does the picture shake
Why does the picture shake ?
Is dit een goede vraag?
Voeg een opmerking toe
Manta schroevendraaierset
112 bitjes voor elke reparatie.
Upgrade Your Toolbox
1 Antwoord
Het nuttigste antwoord
Deanna Sims  this could be an issue with the input sources. Make sure that your cables are all clean and seated properly. If you are uses a cable box etc. try a reboot. You also want to try all other input sources like coax, composite, HDMI etc. If none of this will make a difference then you are most likely having to remove the back of your TV and check the main board as well as all teh cables going to it. If you can post some video on youtube or other sides so we can see the shaking. It could also be the backlight that does some flickering and is perceived as shaking. We need to se what you see
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Deanna Sims zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 23
