Ga door naar hoofdinhoud
Repair guides and support for phones manufactured by Oppo Electronics Corp.
390 Vragen Bekijk alle
My Oppo a57 Can't connect to the camera
Please help me guys ano pwedeng gawin dito na madali ano ang best solution na try ko na yung Clear cache and clear data and forstop and reboot backup reset istill not working ano po madaling gawin please help me Thankyou Respect and Godbless
Is dit een goede vraag?
Score 2
3 opmerkingen
Storage unavailable Keno
door
Hello cannot connect to the camera Oppo A 57
door
Slt, en fait j avais le même problème, de que tu ouvres l'appereil photo un message apparaît (storage indisponible
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hello Ashley...! why don't you try to install an alternative camera application from the Playstore and try to take a snap through that ...if the camera works then there is a problem in your built in camera application ,if the camera does not even work the alternative application then u have to replace the camera or check weather the connection are properly assigned are not.......!!!!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
still not working :(
door
Voeg je antwoord toe
Ashley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 33
Altijd: 3,311
