Ga door naar hoofdinhoud
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
507 Vragen Bekijk alle
iMac 27", 3.4GHz Quad-Core Intel Core i7, 8GB 1333MHz DDR3 SDRAM - 2x4
I am not sure if my computer is an EMC 2429 or Model A1312 and I am not sure where to find that information. I am seeking to replace the graphics card. The info I have is listed in the Question Title.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
OK lets see if we can make sure what you have here. If your system is working at all you can go to the 'About This Mac' and locate the systems info as well as its serial number which you can use here: EveryMac - Lookup to find more details of your system.
If your dedicated GPU is gone you should still be able to boot your system in Safe Mode (and look at the 'About ...'). Or look at the bottom of the stand foot to locate the systems serial number to look up.
Here's a listing of the systems built in 2011 EveryMac - 2011 systems If you remember the year you bought it.
If you're sure of the size, CPU and it's clocking then this is your system: iMac 27" 3.4 GHz i7 (Mid-2011)
Once your sure let us know what you have for sure.
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
Look on the bottom of the stand if it won’t boot up to look at “about this Mac”..
For full exact data use the serial number located on the stand and input it here:
https://everymac.com/ultimate-mac-lookup...
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Lennox Archibald zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 47
