Ga door naar hoofdinhoud
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Vragen Bekijk alle
What's the best way to repair two broken pins in the dock connector?
My iPod has two broken pins inside the dock connector, and I do not want to replace the entire assembly because it is soldered to the logic board.
Is there any other way, for example desoldering the individual lightning port area and soldering a new one on?
Thank you to anyone who helps me with this.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Went to a repair shop, they did it for me.
Was dit antwoord nuttig?
The best way to repair two broken pins in the dock connectors is to &&^& yourself! You suck! Go die in a hole! You are an @%^$$@$!
1 Opmerking:
Delete your account.
door
Voeg je antwoord toe
Eric Zhang zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 40
