Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
Lightly water damaged iPhone SE - issues with corrosion and speaker
I recently bought an iPhone SE from eBay in a lot of devices. The iPhone SE works, except there is corrosion near the battery connector, and the loudspeaker does not work.
The corrosion is in a small area to the right of the battery connector, it doesn't seem to cover any important components.
I was worried the audio IC was busted, but the earpiece and headphones work, so it seems to be a problem with the speaker itself.
I intend on saving the phone, because the water seemed only to affect the lower third of the phone. I replaced the loudspeaker with one from a working iPhone 5S, but the issue still continues.
In short, how do I tackle these problems and prevent the phone from further damage?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
how does the contacts look for the speaker on the charge port? Are they corroded? I would replace the charge port also as water can damage the wiring inside the charging dock connector!
Was dit antwoord nuttig?
Voeg je antwoord toe
Eric Zhang zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 145
