Ga door naar hoofdinhoud
BLU Users: Known issue is occurring after updating, preventing you from logging in. Update at your own risk! Released December 2015 as a budget smartphone from BLU.
61 Vragen Bekijk alle
Can't connect to voice network
I have the BLU Advance 5.0 HD dual-SIM handset. I've put two Koodo (runs on Telus) SIMs in it. One is on a voice-only plan, the other is on a data-only plan.
I told the phone to use SIM 1 for calls and texts, and SIM 2 for data. The data seems to be working but when I try to make a call I get "Celullar network not available".
If I go to Settings > More > Celullar networks > Network Operators > Search networks, for SIM 1 (voice & text), I only get "EXT 2G", while for SIM 2 (data) I get "Koodo 3G", "302520 3G", "302500 3G", "Bell 3G", EXT 3G", WIND 3G".
Am I doing something wrong? I can I get voice working on this handset?
Thanks!
=andrew
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
I found the answer: the handset has only 1 3G antenna (+1 2G antenna) so if you use 2 SIMs, one is on 3G and one is on 2G. Koodo never supported 2G (and I think AT&T has dropped it, though TMobile is still hanging in there), so voice will never work if there's another SIM set for data.
=aw
Was dit antwoord nuttig?
Voeg je antwoord toe
Andrew Webber zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 14
