Ga door naar hoofdinhoud
The Samsung NX3000 is an interchangeable lens camera released in May of 2014.
11 Vragen Bekijk alle
Lens makes a grinding noise when I turn the camera on and off
I have a nx 3000 samsung camera it makes a grinding noise when I turn it on and off. It also requires me to manually help it when I turn it on and off. Can anyone help me with the possible problem. Is there any other lenses that are compatible for this camera as Samsung has discontinued making this camera.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Sounds like some dirt or grit between the barrels of the lens. Have you used it on the beach? We have some basic sugestions on how to clean it on the Restart Wiki at https://therestartproject.org/wiki/Compa...
Was dit antwoord nuttig?
Score 1
Could be the ultrasonic sensor cleaning if you’ve set it to clean on power on/off.
Voeg je antwoord toe
Karin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 3,164
