iPhone X camera glass replacement with water seal?
When replacing an iPhone X camera glass, does it break the water seal?
Is dit een goede vraag?
Annuleer
Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
Rep: 1
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkelit will unless you get the proper foam adhesive used to reseal it, and apply the lens in a dust free environment, without getting your fingers on the adhesive. Essentially, good technicians are trained to do this, and will have access to the proper parts for the repair. If you absolutely want the ip68 classification to stay in tact, then you will need the above repair done.
HOWEVER! getting the device repaired outside of manufacturer facilities will remove the ip68 CERT. This certification is ONLY from the manufacturer, and not given by anyone else.
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 58
Altijd: 1,049
