Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
1839 Vragen Bekijk alle
iPhone 5S vs 7 in battery performance. 7 sucks, why?
So I've decided to buy an iPhone 7, it's on iOS 11.3.1 (DFU Restored)
My iPhone 5S is on iOS 8.4
Battery Stats:
iPhone 7: 303 Cycles, 12% wear, apparently from Battery Info Beta
iPhone 5S: 277 Cycles
I charge them both up to 100%, below's the results.
iPhone 7 lasts 40 hours standby.
iPhone 5S is 80+ hours standby, I had to use it, though had 24% left.
So what's going on here..? Where's Apple's 10+ days Standby claim? Really tempted to resell because of this..
Usage times iPhone 5S wins by 15-20%.
iPhone 7 lasts 4 hours.
iPhone 5S lasts 5.
Why is iPhone 7 battery so bad?
Please forgive frustration.. but this is quite ridiculous to see an iPhone 7 claiming better battery efficiency, only to die twice as quick.
What can be done to fix it, or make it more efficient?
I've tried turning off background app refresh, email push, bluetooth, etc.. soon to get a battery replacement, though if standby times are this crap.. what's the point? Could a battery replacement truly help this issue? (It is after-all 2 years old)
Looking for a scientific answer here somewhat..
Thinking I should resell and get a 7+ instead.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If the iPhone 7 is on 11.4 there is a bug with 5GHz wifi that causes fast battery drain so try using 2.4GHz wifi.
Also the battery life feature in iOS has a different percentage reading than compared from 3Utools so check the battery health via 3Utools too.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Sumona Florence zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 95
